I'm looking for a good GPS
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Carey Mahoney, Mar 28, 2006.
  1. Carey Mahoney
    Carey Mahoney
    Can you guys reccomend an in car GPS or PDA with GPS that is for UK use only. My budget goes upto £230. Thank you.
  2. runner125
    runner125
    Dec 13, 2004
    75
    +3
    TomTom One - does what it says on the tin. :smashin:
  3. Carey Mahoney
    Carey Mahoney
    Cheers mate. Is it as good as the TOMTOM GO300 ? Also what are the directions like?
  4. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
  5. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
  6. Carey Mahoney
    Carey Mahoney
    Cheers mate. I saw that TomTom one but was wondering about the fact it's refurbished. Is that necessarily bad?
  7. runner125
    runner125
    Dec 13, 2004
    75
    +3
    Here are some quotes from other threads about the TomTom One processor etc....
    The One has the better SiRF Star III GPS receiver in it, so will get a
    better signal/reception than the 300.
    The Tom Tom one is supposed to have a better processor inside,
    (it does, almost twice the size/ speed) and people
    on other forums say that the reception problems which can happen with the
    300 dont happen with the tom tom one.
    They both have there advantages but the tomtom one has the latest processors
    so it can replan routes alot quicker also I here people say that the 300s
    reception is not as good as the one the down sides to the one is the battery
    as it is booked to last an hour but to be honest mine lasts about 2 and half
  8. Carey Mahoney
    Carey Mahoney
    It's very tempting. I was also considering Sony products because of the reliability. WHat are TomTom like in reliability terms?
  9. runner125
    runner125
    Dec 13, 2004
    75
    +3
    Don't know anything about their reputation but have not had any problems with mine that couldn't be cured by just pressing the reset button since I purchased it in December .
  10. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
  11. Carey Mahoney
    Carey Mahoney
    I was looking at the Sony NVU50. So you both reckon the TomTom One is the best and cheapest option?
  12. bibamus
    bibamus
    Dec 10, 2005
    1,057
    Suffolk
    +43
    You could always try the Garmin C310. Garmin are a well respected GPS designer and manufacturer, I have used their products for over 10 years, never had a problem with them.
    I think Halfords are selling them at around your budget at the moment. Maybe worth a look?
    Allan
  13. Carey Mahoney
    Carey Mahoney
    It's rather confusing. I want a reliable one, that has good reception etc. TomTOm so far seem to have it, though they say Sony are rapidly catching up. I'll see the Garmin too, cheers mate.
  14. RekalinSimms
    RekalinSimms
    I really liek the TomTom devices. I have been using a GO 700 for awhile and relaly like what I see in their new products that will be coming out soon, especially the 510 and 910.
  15. johnh89
    johnh89
    i got a tom tom one for xmas all i can say its brill.not let me down .
  16. Carey Mahoney
    Carey Mahoney
    Cheers guys. I went for the Sony for some reason. I know everyone says TomTom, but I just trust Sony. Dunno why...
    That site you set up mate was class. Keep up the good work and cheers to all for your help/suggestions.
