I'm having problems with the Denon 2803. Can anyone help me please.
tony kop77
The amp at the back has 4 optical outs. I have connected my dvd player to optical 4 and my sky to optical 3 but if I try to conect any of the previous 2 to optical 1 or 2 or my xbox to optical 1 or 2 it does not seem to recognise it.
I dont know what I am doing wrong, I would have thought it would detect there is something in optical 1 or 2 and just work.
engaged
The 2803 has optical inputs, not outputs. Have you actually set up the digital input assignments using the on-screen menu?
tony kop77
How do I set it up so I can get optical 1 and 2 to work? I did not do anything to get optical 3 and 4 to work, I just connected my dvd player to the amp and it worked same with optical 3.
engaged
It does sound like you need to set up the digital input assignments, enable the optical inputs 1&2 and assign them to specific sources. You need to connect the 2803 up to a TV and run through the set up - I don't have the instructions at hand as I'm not at home.
tony kop77
Thanks for your help engaged. I have just connected the amp to the tv and I am trying to get the set up menu on screen by pressing system set up on the remote but it wont come up.
I had a problem trying to get the menu up before but just messed about with it and got it up in the end.
Same with the off button I have to press zone maine 1 off to switch it off rather than the off button on the remote.
tony kop77
Thanks engaged got the set up menu up and told it that there is a digital connection to input 1 and it worked.
Bit embarassed now, my old amp was an old yamaha and it was not as flashy as the current amp and optical 3 and 4 just worked without me doing anything.
Thanks for your help.
engaged
Pleasure.
I only got my 2803 a month or so ago, and was on the phone to Sevenoaks within minutes of getting it home - in a panic as I couldn't get the banana plugs in the speaker connections. How was I to know about the little black plastic bits that you have to prise out...!
tony kop77
I got the banana plugs too but found them a bit loose so did not bother using them. I like the amp, I only have it on -15db max normally it is about -18 or -20.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
