I'm happy now that my HTPC is working !!
Discussion in 'Desktop & Laptop Computers Forum' started by cosmic023, May 24, 2003.
  1. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi All,
    Just a quick note to say that my HTPC is working ok now, after all the problems i've had.
    Even better now as i've just finished building a new screen for my DIY video projector !! ;)
    Obviously there is still the noise problem to deal with, which can be solved with silentdrive sleeves & quieter fans.
    I know there is more to be done, but the quality is amazing over my standard dvd player.
    Is there a way i could convert the RGB out on my dvd player to vga ?? As my Pioneer 105SZ slot loading dvd drive is fussy with some discs, and refuses to play them in PowerDVD.
    Any sugestions ??
    Cosmic023
  2. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Hi i would have suggested a RGB to VGA convertor from JS Tech...but i don't think they are compatible with most projectors? I know they do a RGB to Componant convertor which might be more useful if you have componant in on the projector.
    www.rgbtosvideo.com
  3. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi Loafer,
    It's an diy projector, and not a standard one. It's an LCD panel (ASK Impact 24) and a 400w Overhead projector.
    It's had many modifications to suit my needs, it has connections for comp. video & s-video and vga.
    It doesn't do Componant video, but it might do with an RGB 2 VGA converter ??
    I'll have a look at the Keene site sometime, and see if that'll do the trick ??
    It's a fussy panel, but the picture quality it great for an 640 x 480 or 800 x 600 (Compressed into 640 x 480) when using VGA via the HTPC !!
    Cheers 4 now
    Cosmic023
