Im going INSANE
Discussion in 'PC Gaming & Rigs' started by MrBurns, Oct 21, 2004.
  1. MrBurns
    MrBurns
    Plz can u guys help. My broadband connection is messed up. At the bottom of my screen it says "local area connection,speed- : 1.1 mbps, status- limited or no connectivity. Then it will some times say "local area network cable unplugged, and my bt modem goes into "training" and slows down. How in the blue hell do i fix this? Can i just turn of my lan connection all together? If i disable the lan connection then my modem recieves no signal.
    Kind regards,
    Jamie :confused:
  2. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    tried ringing your provider ? Thats the best place to start ..
  3. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    You could try asking on the forums at www.adslguide.org.uk to get more of a response, there's a lot of helpful people over there.
