I'm confusing myself can someone help.
Discussion in 'Cables & Switches' started by bongloid, Sep 11, 2012.
  1. bongloid
    bongloid
    Apr 2, 2010
    My set up is
    Front room Set up is
    Virgin box into hdmi splitter one cable goes into the main tv in the front room and the other cable ( 15 meter) goes into the bedroom tv.*
    This allows me to watch virgin in the bedroom no problem.
    Bedroom set up is
    Pc goes into bedroom tv Using a hdmi cable.
    How can I use splitters to get the pc to show in the front room using the 15 meter cable that's already there.*As well as keeping the virgin*
  2. Member 614390
    Member 614390
    Aug 23, 2012
    4
    4
    Shepperton, Middlesex
    Hi there,
    Hope i've not misunderstood...unfortunately it's not quite as simple as using splitters to make a HDMI cable handle 2-way traffic. Simplest way would be to run another HDMI cable, alternatively move your sources (Virgin and your PC) to one area and use a 2 input HDMI switch with a splitter / 2x2 matrix to distribute your AV to multiple screens.
    Happy to talk you through your options if you wish... 020 3137 9184 (Lektropacks)
    Aiden
