Im banned from XBOX live
dUnKle
Can it be fixed ?
I have modded box (chipped and increased HD) which got banned from Live after Halo 2
can anything be done to "reset" the console and get back on Live ?
John
Hi Duncan ,
I believe so . I've never seen it discussed on here , but have done over at XBOX-SCENE
John
John
DuncanWardle said:
not tried
I can never got on there :thumbsdow
Xbox-Scene = info overload :eek:
Try this link.
I have not read further than the first page but , according to the title it will eventually tell you what to do :smashin:
good luck
John
explicitlyrics
Established Member
Basically, to get onto live again, you will need a fresh (unbanned) EEPROM. This is basically the serial number of the xbox. It can be replaced by buying a code off the internet and then loaded onto the xbox. I believe you can get codes off e-bay (subject to usual risks) or http://forums.xbox-scene.com in the buy/sell area.
Once you have loaded the code (see a tutorial on www.xbox-scene.com ) then live should work as normal again.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
