Ikea Stuva (A Deeper Besta?)
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by sjackson, Jun 11, 2015.
  1. sjackson
    sjackson
    Jan 8, 2006
    2,189
    116
    Ireland
    +539
    Is anyone using the Ikea Stuva as an AV cabinet?
    From looking at the specs it looks exactly like the Ikea Besta but 10cm deeper which might make it perfect for an AVR etc.
    STUVA Frame - IKEA
    Hopefully the Besta doors etc will fit
  2. porscheman
    porscheman
    May 25, 2010
    532
    3
    Wokingham, Berkshire
    +94
    I think you will be better off with Besta, as it has more door options, including a dark smoke glass door which is obviously IR remote friendly. I agree that the depth is a problem, but the back board on the besta is easy to cut cable access holes into, or potentially just leave removed so your av kit can breathe.
