Ikea Besta Sliding Doors
sep8001
Hi I have just bought the BESTÅ - Shelf unit/ height extension unit as per the link below:
http://www.ikea.com/gb/en/catalog/products/70137194
I know a lot of people have used these but could not find a post anyone that have the above with the sliding doors.
Does any one have these with the sliding door and how does it work? Can I have two door or does it only work if I use one door?
Thank you
jennypatel
Yes, I had seen in the mall where 2 front doors were at the entry. One front door is the way to the gift shops, while the other front shop is the way to the gaming section. So, you can also place both the front doors at the entry and both can be used for different purpose.
DavidT
Thank you
I can't see the point of having sliding doors on this unit as you will only be able to have one door which will look a bit odd. I would go with the normal glass doors if I were you.
David
