IKEA Besta Burs Question
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by isherdholi, Jan 9, 2012.
  1. isherdholi
    isherdholi
    Nov 14, 2007
    23
    3
    Hi All,
    I'm looking at buying a Besta Burs: -
    BESTÅ BURS TV bench - high-gloss black - IKEA
    I have 2 questions about this: -
    1) Will my KEF HTC3001SE centre speaker, which is 13cm high, fit inside one of the centre compartments?
    2) There are two large drawers on either side. Rather than fitting the runners in and using it them drawers as intended by Ikea, I want to just put some hinges on the drawer front, and use it as a door with shelving inside. Is this possible? Anything I should be wary of? Has anybody done this?
  2. hp1980
    hp1980
    Nov 12, 2011
    82
    Prob difficult to get an answer on something like that - prob best to nip down to the local ikea and check it out (they normaly have a lot of units in their living room disaplys)
  3. hp1980
    hp1980
    Nov 12, 2011
    82
  4. isherdholi
    isherdholi
    Nov 14, 2007
    23
    3
  5. hp1980
    hp1980
    Nov 12, 2011
    82
    Doh. My bad
