IK Multimedia Announces ARC 2
Discussion in 'News' started by hodg100, Jul 27, 2012.
  1. hodg100
    hodg100
    Reviewer & News Writer
    Aug 8, 2005
    14,105
    3
    4
    +4,467
    Advanced Room Correction System for Musicians
    IK Multimedia in collaboration with Audyssey has announced Version 2 of ARC - Advanced Room Correction System - for Mac/PC DAWs (Digital Audio Workstations).
    As many of you will know, ARC works by measuring your room using the included measurement microphone and software and then generates an algorithm to provide a correction of your room's acoustic problems.
    MultEQ XT32 gives the new ARC 2 an even higher-resolution EQ adjustment - especially in the extreme low frequencies where correction is usually needed the most along with a more natural and smooth midrange and high frequency performance - a combined L/R correction for high-quality control room optimization and customizable target curves so you can shape the final response of your monitors. All of these new features are packaged in a completely new interface featuring a new Monitor Control panel interface for optimized control.
    ARC 2 features enhanced resolution across the entire frequency spectrum including 4 times greater resolution in the lower frequencies where room distortions typically occur. ARC effectively flattens the low-end frequency response and also improves the mid and high frequency ranges to make the correction process totally transparent.
    [​IMG]
    The new MultEQ® XT32 algorithm in ARC 2 provides greater resolution with fewer measurements allowing you to get a better degree of accuracy faster. Now only 7 measurements are needed for the software to calculate accurate corrections to your listening environment.
    ARC 2 is now shipping from IK Multimedia and its network of professional music resellers worldwide at a price of €249.99 (ex VAT).
    For more information and video demos, visit: ARC System 2
