Ignorant Nebula and FFDshow questions
Discussion in 'Desktop & Laptop Computers Forum' started by TB, Apr 28, 2005.
  1. TB
    TB
    Nov 28, 2000
    104
    London
    OK excuse my ignorance, and I have had a good search on the forums first.....
    I have HS20 pj and use a HTPC to watch movies. I use powerstrip (for res) and then zoomplayer / ffdshow and dscaler for movies and the picture (to my eyes) is stunning. So much better than the bog standard packages (windvd / powerdvd etc..).
    So much was the improvement that I'm keen to use ffdshow with my new (sitting on my desk at work) usb nebula for digi TV. Apparently the software that comes with the card does not tie in to ffdshow....soo my question is: is there an application that will play live tv (not the recorded product as I assume zoomplayer will do this) that ties into ffdshow. The TV card will mainly be on my study pc where I'll use the nebula software for all my recording tasks, so this is just for live tv via my pj.
    Thanks for your help. TB
  2. groovyclam
    groovyclam
    Mar 28, 2004
    202
    Very simple answer - no.
    Nebula are yet to release BDA drivers for the PCI card/usb-box and until that time you have to use their DigiTV app for watching live/timeshifting and recording TV progs.
    They have released an SDK toolkit recently for developers to start including in the compilation of any software they might want to write and maybe someone will write an alternative to DigiTV before Nebula bother to create BDA drivers.
    Having said all that, I believe that Showshifter can be used with the Nebula but am not sure if you can tie FFDShow in with that in any way - I suspect not but suggest you download the trial of Showshifter and see.
    An excellent forum for Nebula users is: http://www.digitv-forum.co.uk/
  3. TB
    TB
    Nov 28, 2000
    104
    London
    Hmm will give showshifter a try. Tried the Nebula last night and am not overly impressed. Ho umm will perservere.
  4. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    have you set the deinterlacing correctly? the PQ is pretty poor until you do that I found.
    regards,
    owain
  5. TB
    TB
    Nov 28, 2000
    104
    London
    Where do I set that and what do I set it to?
    There only seemed to be three options as I remember?
  6. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    you set it in the video panel of the settings screen IIRC (in work at the moment), try setting it to Bob, that improved things a lot for me with video based sources.
    If this isn't helping what problems are there with the nebula compared to dvd? anything specific that's bugging you?
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Use bob for video or screwed up film transfers , use none for solid film or frame based material .
  8. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    hi mrD
    I tend to leave mine on bob all the time, is there a problem with this?
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Not really although you might be able to obtain a little extar sharpness if you leave it on off with film based material. The bob that the nebula uses isactually quite a good one of this type. The other option (average I think) is not worth using unless your PC is low spec and can't handle the bob one.
    Also use the frame smoothing option with multiples other than 25. (ie the HS20 in full 1:1 panel mode) this will give you a regular repeat frame pulldown that will improve judder.
  10. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    say what?!? and there was me thinking I was getting to grips with some of this HCPC/video mallarky! ;)
  11. TB
    TB
    Nov 28, 2000
    104
    London
    Thanks for all this. I'd still much rather be streaming it via FFDShow.
    The DVD picture I have is fabulous.
  12. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    I suppose you could always just record things off it and watch them with a player that supports FFDshow? Probably not the solution you want though? Actually, I've never tried this but maybe you can start playing the recordings with another media player before nebula has finished recording them? start recording a programme then after a couple of minutes start playing the file with something else, quite possibly won't work and you'd probably need a pretty powerful PC but might be worth a go for curiosity's sake.
    good luck whatever,
    owain
  13. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Nebula locks the files its recording , the only way to view them at the same time is with the nebula app. Look on the bright side its not the worst player in the world , by a long shot.
  14. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    oh well, never mind, probably a daft idea any way!
    agreed, I actually find it quite good on my TV, certainly better PQ than sky a lot of the time. The one thing that puts me off it a bit is the judder, makes watching football a bit of a no-no for me. I'll have a look at that frame smoothing thing you suggested and see if that improves things a bit.
  15. groovyclam
    groovyclam
    Mar 28, 2004
    202
    Not true.
    Nebula does lock the files but ZoomPlayer can play locked files.
    Setting up ZoomPlayer is not the easiest thing in the world to do but it is an excellent player when you have it all setup correctly.
    I watch Nebula files using ZoomPlayer configured with the Elecard splitter and NVIDIA DVD codec and get fantastic results.
    The way ZoomPlayer plays back files which are still being written to is that it plays back the chunk that was there when you started and when it gets to the end of that it reloads the file at the size it is now and carries on from the correct point.
    The reload/restart takes about 1/2 second of blank screen so unless you already have about at least 20 mins of file recorded when you start it is annoying because ZoomPlayer will have to reload/restart every 5,10, whatever, minutes you had when you started.
  16. groovyclam
    groovyclam
    Mar 28, 2004
    202
    And I forgot to say that you *can* put FFDShow in the chain of playback filters with ZoomPlayer.
  17. TB
    TB
    Nov 28, 2000
    104
    London
    Hmmm nice one could be a partial solution. Thanks for the ideas.
  18. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
    How exactly do you do this :confused: As far as I can see it's just an on/off tickbox.
    Thanks, Val
  19. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    settings , video , enable frame smoothing.
  20. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    But what do you mean "with multiples other than 25" mine doesn't seem to have an option for that?
    EDIT: oh, hang on, you don't mean theres an option for that you mean if your display scan frequency is not at a multiple of 25, right?
  21. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    yup
