igix DVR3000 NTSC/PAL system auto-conversion
Discussion in 'Blu-ray & DVD Players & Recorders' started by johnsteed, Aug 29, 2005.
  1. johnsteed
    johnsteed
    The description of the specifications for the Digix DVR3000 recorder state
    NTSC/PAL system auto-conversion.
    http://www.digix.com.sg/dvdrecordable.asp
    I was looking for a way to covert PAL recordings to NTSC but gave up since I would need a converter costing a few hundred pounds which was not worth it for the number of recordings I wanted converting.
    I have come across this dvd recorder that supports multi-signal incoming source recording but I think they don't mean coverting PAL to NTSC or visa versa.
    Anyone like to offer their comment on the definition of NTSC/PAL system auto-conversion?
    Thanks.
