I am happy it worked fine for you. There are quite a few solid online radio stations for audiophiles. Some of them in FLAC, high-res. Paradise is definitely one of them.Unfortunately the application does not work properly. More precisely, I can't access any radio station. I don't know why but it shouldn't happen considering we're talking about a pretty expensive product... Tidal and Spotify connect works very good.
It is recommended to keep the maximum volume on your digital source and control the final volume on your analogue circuitry. Did you manage to find out why Spotify is not working 100%. I would suggest updating Spotify and Stream's firmware/software.I play Spotify Connect on my Stream, but the volume is reset to only 50% every day, even if I raise to 100% again (using spotify app on android mobile).
I think 100% must be the recommended setting for the best sound quality, or not?
I think that is the best, keeping it at max. But the Ifi will drop to the 50% level.ok, so the issue is that with that two streamers Spotify defaults back to 100% volume?
When streaming with the Ifi, volume will return to 50 percent on every powerup, even though I keep raising it to 100 percent when playing.ok, so the issue is that with that two streamers Spotify defaults back to 100% volume?
@realsand Please, try the following path in settings: go to settings > General playback option > Volume control > Set Mixer type to “Software''I think that is the best, keeping it at max. But the Ifi will drop to the 50% level.
I could be wrong, but I believe that full volume setting on the app setting is preferred(?)
I also have another streamer (Onkyo) and that one stays at full volume.
As @Cebolla has mentioned the first unfold is done by the Roon and the Zen Stream is passing the signal to the DAC. So in this case, the first unfold function should be disabled or left on auto) in the Zen Streams' settings. It's not needed. The second and third unfolds are only available in MQA certified DACs.Hello,
I own a Zen Stream and I have it going over USB to a Denafrips Ares II Dac (non MQA DAc). I listen to MQA files using Roon/Tidal.
From my understanding, the Zen Stream is both a MQA decoder and renderer. When I look at the Roon I see the following:
Source: TIDAL FLAC 48kHZ 24 BIT 2CH, MQA 192KhZ
Authentication: MQA Studio 192kHz
ifi Zen Stream: Roon Advanced Audio Transport
Output: USB Output
The LED on the Zen Stream is Blue.
I was under the impression that the output to my DAC would be 192Khz, but looking at the leds on my DAC I am seeing 48Khz.
Can someone explain?
Thank you in advance.
I can see two solutions for your issue. First, we have to start with the obvious part. Have you updated the software to the latest version and can you let me know what version it is?Hi everybody. I have triste zen stream plugged by usb on Cayin Cs55 with integrated Dac. In AIO mode i see the Dac on USB output but if i switch on dedicated Roon mode, i see only the spdif output. I m very disappointed, please help
Whatever happened to the ZEN Stream doing the first unfold? I remember reading a post that this was being worked on and there would be a switch to turn this on and off in firmware. As well, a beta firmware would be available.As @Cebolla has mentioned the first unfold is done by the Roon and the Zen Stream is passing the signal to the DAC. So in this case, the first unfold function should be disabled or left on auto) in the Zen Streams' settings. It's not needed. The second and third unfolds are only available in MQA certified DACs.
We have made some progress on that, but it's still not good enough for us. We would rather hold it a little more than disappoint.Whatever happened to the ZEN Stream doing the first unfold? I remember reading a post that this was being worked on and there would be a switch to turn this on and off in firmware. As well, a beta firmware would be available.
Hi Ifi, thks for your return but if i switch in another mode, i dont see Usb, and the Dac is on... in Aio, i see usb and spdif and i can select in ifi software but With roon in exclusif mode, Hé dont workAs @Cebolla has mentioned the first unfold is done by the Roon and the Zen Stream is passing the signal to the DAC. So in this case, the first unfold function should be disabled or left on auto) in the Zen Streams' settings. It's not needed. The second and third unfolds are only available in MQA certified DACs.
What you can do about your problem:
1. Go into settings at "http://ifi.local/plugin/audio_interface-alsa_controller" and see if the USB output is selected properly as an output device.
2. When you set up your Zen Stream and change the mode to Roon, please make sure that DAC is connected and powered on. The Zen Stream deactivates USB output if it is not connected to a DAC.
Let me know if that helped![]()
I am having the same issue after the latest firmware update. I opened a ticket, said on the ticket I had installed the latest firmware, the response was to install the latest firmware. I reopened the ticket (45092)Hi Ifi, thks for your return but if i switch in another mode, i dont see Usb, and the Dac is on... in Aio, i see usb and spdif and i can select in ifi software but With roon in exclusif mode, Hé dont work
