If your XBOX 360 won't connect after MCE has been in standby then read on
Discussion in 'Microsoft Windows' started by TiVoMad, Mar 20, 2006.
  1. TiVoMad
    TiVoMad
    Jul 13, 2005
    449
    Orpington
    +82
    I have an XBOX 360 as an extender to my MCE machine and have always had a problem getting it to connect after the PC has come out of standby. There is an MS KB article about this which just tells you to get the latest network card drivers and if that doesn't work then don't use standby - really useful, NOT ! Anyway, to cut a long story short, I found out how to fix this problem. You have to go in to the device manager and select the properties for the network adapter. There should be a power tab. On this tab, there is a check box which says something like 'Allow windows to switch off this device to save power'. This box is checked by default - un-check it and click 'OK'. You should now find that the problem goes away :) I suspect this is not a problem with all network adapters but for mine which is a 3com Gigabit on an ASUS motherboard it certainly was.
  2. Cronan
    Cronan
    Thanks for the note, I'll try this tonight
  3. spin20vt
    spin20vt
    Jun 7, 2005
    116
    +7
    Thanks mate ill try that, this problem was annoying the hell outta me
