If you were spending £150 on a HIFI amp 2nd hand what would you get
Discussion in 'Hi-Fi Stereo Systems & Separates' started by kwack, Feb 20, 2013.
  1. kwack
    kwack
    Sep 6, 2002
    170
    watford, england
    Decided that best bang for buck so to speak that a 2nd hand amp could be the way to go.
    Thing is there are just so many to choose from and I havent much experience in terms of sound quality etc. It will be paired to a set of Diamonds 10.1 which I m told are quite neutral and a Denon Music Streamer DNP-720ae
    I have seen items from Cambridge 640a, Rotel RA range, Nad C320bee, Arcam stuff.
    Is it just a case of watching all of these and picking one which meets my price range. They are all from respected companies so sound wise they are going to be better than my JKVC all in one (20+ years old)???
    Any thoughts/comments
    KWack
  2. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,660
    London
    +728
    It more of a case of what amp works well with the speakers you have and all of the one you have suggest i would of thought work well with the 10.1. It just how it sounds to you. Also music tastes must also be taken into consideration as some amp are better with some genre than others. Or even made with a certain genre mind.
    To add to the list - Marantz PM6003 amplifier. Should be around the £150 price tag s/h
    A Nad C352 amplifier might also fit within budget.
    A couple on that well known auction site currently which looks as though they will go around the budget price
    nad c352 amplifier
  3. robertseymour
    robertseymour
    Jul 24, 2006
    637
    Swindon/Oxford
    +80
    Rega Brio3 and Sony TA-F670ES would be worth a look.
  4. DIBSTER
    DIBSTER
    Mar 19, 2008
    902
    46
    Manchester, England
    +119
    If you see any on the well known auction sites, I would heartily recommend a Marantz PM7001. These tend to go for anywhere between £120-£150 dependent on condition etc. Top amp.
  5. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,660
    London
    +728
    Really!! as low as that?
    Not that i've been looking and it has been a while since i last checked, but i've only seen them go for nearer the £200 and a little above. Can't find any for sale now, so can't gage a price.
    Definitely agree with being a top amp. Awsome in fact, but then i'm bias because i have a KI version ;)
  6. juggler
    juggler
    Apr 5, 2006
    374
    28
    +43
    When I was looking at second hand amps a number of factors helped me narrow it down. Do you need:
    • a remote control?
    • Subwoofer or pre-amp outputs?
    • Lots of inputs or just one?
    • A phono stage for a turntable?
  7. kwack
    kwack
    Sep 6, 2002
    170
    watford, england
    Thanks for advice. Definitely want a remote and not too worried about number of inputs as I will only be plugging in my Music Streamer.
    One of the concern is that I cant tell how old some of these amps are
    I have seen Nad c352, Rotel RA04/05 and Cambridge Azur 540a/640a all around this mark. But not sure what is better, older etc
    I don't want to buy something that needs servicing if there I such a thing as servicing
    Kwack
  8. Tone-uk
    Tone-uk
    Apr 3, 2009
    1,389
    63
    London
    +177
    Buy a new one - like the Marantz pm5004! Nice warranty, know there's nothing wrong with it etc etc. It'll sound as good as any other really - just as long as it doesn't clip (only 45-50w)
    Only 45-50w but Wharfedale sensitivity 86db/1w/1m. With 40w you'll get to over 100db - which is loud.
  9. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Mission Cyrus II and PSX
  10. Just Old
    Just Old
    Jul 20, 2011
    1,367
    113
    Dumfriesshire
    +550
    I agree fully with Dibster...it's an excellent amp.
  11. kwack
    kwack
    Sep 6, 2002
    170
    watford, england
    thanks for the advice. as i have had an old jvc adagio system for best part of 20 years what have i been missing over a decent amp?
    i will be playing many types of musix from rock.pop.house.hip hop that have been flac to nas and played thru my denon dnp720a.
  12. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    Sony ES
  13. Arfa
    Arfa
    Apr 25, 2006
    1,077
    London
    +71
    Sony ES gear can give you great bang for your buck.
    Otherwise maybe:-
    Exposure XV
    Musical Fidelity A1 (though maybe not quite powerful enough)
    Nad C370
    Or maybe a nice Rotel.
