If You Record From the Hard Drive to DVD in SP Mode Do You Loose Quality?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Fortesque, Dec 29, 2006.
  1. Fortesque
    Fortesque
    Nov 7, 2006
    63
    As title really. Just want to know whether, being a digital signal, any quality at all is lost in transferring from HD onto DVD when using the highest resolution?
  2. alan sh
    alan sh
    Dec 27, 2006
    192
    +11
    Not that I have noticed
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,132
    +7,051
    The answer is - Yes you do.
    The crucial point is whether or not you re-encode... and if you transfer to DVD at anything other than high speed , you are re-encoding.
    High speed copying is the only lossless form of transfer.
  4. Fortesque
    Fortesque
    Nov 7, 2006
    63
    Sorry for being green, but can you explain what re-encoding and high-speed copying are?........in relatioon to a Panasonic EX-75.
  5. aekostas
    aekostas
    Jan 2, 2006
    1,263
    48
    +52
    Every time you write something on the DVDR (HDD/Disc) from an external source or the tuner you are encoding. If you encode an already encoded input (eg copying from HDD to Disc, aka "dubbing") you are re-encoding :)
    You can avoid re-encoding if you set the "High Speed" flag on the DVDR *before* encoding for the first time and then dub in high speed. That's a lossless copy.
    Your manual is your friend ;)
    HTH.
  6. PhilipL
    PhilipL
    Jan 18, 2002
    3,854
    103
    +460
    Encoding is another way of saying lossy compression.
    Most things digital these days use lossy compression, this means when you come to playback (decode) you haven't got everything that was there before you started.
    When you re-encode, this means decoding then encoding again, but because you never get back the original quality when you decode, and lose stuff when you encode (lossy compression), you lose even more.
    Regards
    Phil
