If you have sony box please read
Discussion in 'Satellite TV, Sky TV & FreeSat' started by le hutch, Jun 13, 2001.
  1. le hutch
    le hutch
    I'm just about to buy a Sony digi box - the new version (760 I think). I was discussing the optical digital output with a guy in a HiFi shop and he said that only the earlier boxes have the output enabled as SKY asked sony to disable this output - something to do with wanting all Sky digiboxes to be the same.
    Can anybody clarify this?
    If you have a sony box does the output work?
    Ta! :D
  2. Guest
    Le Hutch, Will this not work posted by DSKDAN previously?... Maybe it only works on the older boxes?
    For you sony digibox owners who bought one, only to find the digital optical output doesn't work (like me)Try this software update:
    Remove card.
    Unplug digibox and wait a few seconds.
    Hold in the backup button on fascia, and plug back in. Keep holding in the back up button until you get an onscreen message saying it's updating software and could take upto 10 minutes.
    Release the backup button and wait.
    When the box switches off, put your card back in and switch it back on.
    Your digibox should now be running the latest software :
    O/s 1.2s3bu, EPG 2.7a.2*, Sony model no. changed to S750.37. and optical output enabled!!!
    :confused: :confused:
  3. GarryF
    GarryF
    Aug 30, 2000
    1,428
    83
    Scotland
    +339
    I followed the above instructions a few weeks ago and can confirm it works. I got my sony box in November last year.
  4. le hutch
    le hutch
    Thanks!
  5. Kemo
    Kemo
    What type of sound do you get out?
    Is it Dolby Digital?
  6. GarryF
    GarryF
    Aug 30, 2000
    1,428
    83
    Scotland
    +339
    No, you get the same as analogue. It may be possible to get DD if and when sky starts brodcasting DD but they will no doubt make it possible only through buying a new box.
  7. bighairy
    bighairy
    You get the same sound as is carried via the analogue Scart output.
    On my system, where I put the optical signal straight into a Yamaha DSP E800, the optical sound is massively better than that carried out via the scart. Better channel separation and much clearer treble and bass. The difference is so great my wife can hear it!
  8. Guest
    Much much better DACs in most processors and some Home Cinema amps! :D
  9. Ars longa, vita brevis
    dolby digital sattelite is avvialable, i saw a box for about £300 maybe more with that logo on it, alas it was in europe and may never make it here.
  10. t-force
    t-force
    May 2, 2001
    1,859
    Southampton, UK
    +150
    If I remember correctly, doesn't the German satellite system broadcast DD 5.1 with its movies (it might be the cable system). So that box just mentioned may be used for that. I wonder if the Sony box would work with it...Any German satellite users around who use Sony DSS decoders?
