If you had a budget of 400 stg
Discussion in 'AV Receivers & Amplifiers' started by Anrasp, Sep 5, 2003.
  1. Anrasp
    Anrasp
    Nov 28, 2002
    69
    Malta
    would you go for the following set-up
    Receiver: Marantz SR4300 or Yamaha RXV430RDS
    Front L + R: Eltax Liberty 5+
    Centre: Eltax Liberty Centre
    Rear L + R: Eltax HT2BP
    or would you maybe go for better speakers and going for a lower spec amp ?
    Anrasp
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    I would recommend the Marantz, they are so cheap now that the drop in performance will not be worth the money you could save by going to a lower spec amp. Not familiar with the speakers though.
