If only
petrolhead
If I was to upgrade my Epson TW100 what would I get. Max price £3500?
LCD or DLP etc etc
petrolhead
Seen the HT1100 but would rather it be a true 16:9 panel
NonPayingMember
Previously Liam @ Prog AV
You'll find that all the projectors in this price category are basically 4:3 1024 x 768 chips only using 576 lines of the chip. What the NEC offers is a 1024 x 576 16:9 installation mode (which gives you all the functionality of a 16:9 projector) or a 1024 x 768 4:3 installation (for those that prefer), or a 16:9 installation using 1024 x 768 pixels and an anamorphic lens!!
It also gives you a better picture than most of it's competitors regardless of the aspect ratio of it's chip!!!! :clap:
Or there is the Toshiba MT8 (1280 x 720) which is now going for less than 4 grand
HTH
petrolhead
I would disagree with the comment "You'll find that all the projectors in this price category are basically 4:3"
Sim Domino 2? 16:9 DLP 1024x768 for one
Benq 8700 16:9 DLP 1280x720
NonPayingMember
Sorry I should have explained myself clearer regarding this price range essentially all being based on 4:3 chips. The Matterhorn Chip (1024 x 576) is essentially the DDR Chip (1024 x 768) just without a whole chunk of lines!
As in the performance is the same (save for a tiny bit of light spill) and the fact that it (the NEC) is 4:3 really shouldn't rule it out because the picture from it is better than most Matterhorn Chip DLPs. Esp given that it can be set into a 16:9 mode and hence behave exactly as a matterhorn chip.
http://www.dlp.com/dlp_technology/dlp_technology_chip_details.asp
Notice there is no 1024 x 768 chipset - Matterhorn projectors and the HT1100 use the 0.7XGA DDR
dapex
Hi, i have just been reading this thread (thanks for the link to the dlp site BTW) and I am now curious to know what a £3-4000 projector could give me that a £1500 PJ cant???
buns
well at £1500 you are in the middle of lcd territory..... most obvious problem being contrast ratio problems eminating from a raised black level. You additionally have the tendency that lower end projectors use lamps which dont do colors true justice.
Spend a bit more and you will start to get over those problems. I have an ht1100 and have to say the step in contrast ratio between it and one of the projectors in the lower range is absolutely incredible.
ad
TheNightFly
Got to admit that going from a 16:9 projector to a 4:3 'feels' like taking a backward step. However, providing you can install adequate masking to soak-up the light-spill from the unused portion of the DMD chip you are at no disadvantage compared to a 1024x576 projector. In fact, you get the added flexibility of being able to use the additional pixels to position the image like a virtual lens shift.
With a fixed screen the masking issue is easily solved but I can see though how it might be more of a problem with a retractable screen. The amount of light spill is quite low but without masking it might be noticeable on occasions - like particularly dark scenes that are sustained for some time.
Check the throw of the HT1100 though, it's quite short and may not fit your room layout anyway.
Allan
petrolhead
Hi Allan
I was very impressed with the Ht1000 but concerned about light spill and the fack that have an excellent masking system.
Had not thought about the throw
Messiah
What about the Tosh MT8. I reckon there's gotta be a few good deals around on this stunning 1280x720 DLP pj with the new MT800 due out very soon. Just a thought :)
Having had both I can tell you it would be a VERY worthy upgrade.
uczmeg
I have the HT1000 and love it.
The 4:3 light spill annoyed me a bit, but the step up from a very similar LCD (LPX500) was massive.
I now have an anamorphic lens for the NEC. So not only have I lost the light spill (it basically makes it a 16:9 projector), I have extra resolution too.
The HT1000 and lens cost me £2350! ;)
There is a 'cheap' nearly new HT1100 in the classifieds. With the rest of your budget get a Prisamasonic lens to go with it.
Marc
