Comer
Established Member
I recently bought an ADSL modem and it doesn't seem to be suitable to use on a home network as it is a DHCP server that only supports one PC. It will only assign an IP address to one PC on the network. This means that if I use dynamic IP adresses only one PC gets an IP address and the others will not join the network, if I use static IP addresses, none of the PCs can access the Internet.
I have spen quite some time onto the modem support section and they have confirmed that it can only be used with one PC. On the modem box it states that the modem "Provides ideal solution for home or small business networks." The support manager agreed with me that this statement is false and that I should return the modem to my supplier. However the supplier (dabs.ie) say that the modem was not falsely advertised and it's my problem. The modem was advertised on the dabs.ie site as "It is an ideal solution for residential or small business CPE deployments." (I assume that CPE is customer premises equipment). My question is, is this the same as saying that the modem provides ideal solution for home and business networks.
Any opinions greatly appreciated.
