If it worth paying extra for decent DVI - HDMI cables?
Discussion in 'Cables & Switches' started by Scottyyy, Aug 30, 2007.
  1. Scottyyy
    Scottyyy
    Nov 11, 2006
    397
    Liverpool
    +13
    edit: doh, I spelt the thread title wrong. I always seem to do that when making threads. Meant to say "Is" of course.
    I've just bought a Oppo 971H, and I stupidly did not research this model (it was also an impulse buy -- literally 23 seconds left on the auction when I looked at it so I bidded straight away after reading description) and did not know it didn't have a HDMI output and the chap I bought from is including a DVI - DVI cable.
    My TV is a Panasonic TX-32LMD70 and does not have a DVI input, therefore I'm in need of a DVI to HDMI cable so I can connect this Oppo to my TV when it arrives. My question is, how much would the cheapy £5 cables from eBay degrade the quality compared to say:
    http://www.tvcables.co.uk/cgi-bin/tvcables/1M-DVI-HDMI-PRO.html
    If there is a big difference I'll buy the better cable, otherwise I'll just go for the cheapy eBay ones.
  2. Ross-P
    Ross-P
    Mar 16, 2005
    400
    UK
    +25
    You will get a different answer from everyone on this subject ! All I would say is to avoid the cheapest ones, The one which you have selected in the link is prob a mid priced one, so if you can afford it I would go for that one.
  3. Scottyyy
    Scottyyy
    Nov 11, 2006
    397
    Liverpool
    +13
    Thanks.
    I already bought one from the classifieds here. Apparantly it's a decent one so we'll see.
  4. JohnWH
    JohnWH
    Jan 23, 2004
    1,826
    48
    St Albans
    +82
    At that length it is pretty much irrelevent how much cable the cable costs. There may well be a difference in the quality of construction but the picture will be the same for all.
    So personally I would have gone for the cheaper option, but still you're unlikely to be dissapointed either way.
    John.
