If I was to buy a DVD player today which one should it be ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by dUnKle, Feb 1, 2001.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,750
    +2,721
    Im willing to pay around £400 maybe more, prefer less on a new DVD player. I have a 1st generation R1 only Toshiba player and also a Pioneer 919E but have heard so many good things about soem of the newer players that I wanna buy a new one, but which one ?
    I want GREAT picture with RGB output.
    I want GREAT sound but do not need in built decoders !
    Has to be MULTI-REGION
    What about the SONY 735 ? Is there a player as good as this but cheaper ?
  2. DaBuzz
    DaBuzz
    Techtronics are selling the Pioneer 737 at £500 Multiregion and its suppose to be a fantastic player.
    Also consider the new Toshiba 500E which has an even better picture than the Pioneer. The RRP is £550, but i am sure Techtronics will do it at a lower price when they get it!
  3. Kahless
    Kahless
    Make sure you consider getting a player that is compatible with DVD audio if your spending £500. I think there are only two machines, there is a review of one in the new HCC.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    DVD Audio for £500?
  5. Guest
    If I was gonna buy a new machine I'd go for one of those Sony 860 multi-changers. But then again I'm a lazy git.
  6. Ace007
    Ace007
    Duncan,
    How about a Pioneer717, they have really come down in price, or were you looking for a newer model?
    Ace
  7. Sam
    Sam
    Nov 6, 2000
    329
    Surbiton
    +9
    I have a 735 and it is a very good machine. All discs I've tried work perfectly (except for R2 Gladiator which glitches on the menu, but the rest of the disc works fine). However it does have a slow layer change, but if you don't mind that its a great player.
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Jeff, the new Toshiba 500E is DVD-A indeed!
    Duncan, I am facing a similar problem (ie need for PAL compability and budget) and have started looking around.
    The Toshiba 200E looks promising though RCE might be a bit of a problem here, now I also tend towards the Sony DVP-S745 (Asian version of 735).
    Will do some auditioning during the weekend of those mentioned.
    Missed the "sale" of the Sony DVP-S705 (=725) for around GPB200 ...
    If those players can't convince me I probably try to get the Sony 7700 from Singapore (around GPB370).
    If I can't eat it, drink it or fudge it, I ain't interested.
  9. Ars longa, vita brevis
    i doubt a 400quid player is going to be noticably better than a 900 quid 3rd gen one, the 919. I would not recomend spending that sort of cash now for what is not going to give much more than rgb connection.
    i would agree that you should wait for dvd-a
    717, is 99 without laserdisc so that would not be wise ace
    Assumption is the mother of all errors
    member formerly known as hank hill, the Jesus H
    but he got bored of that so changed to some latin sh*t
    'which is nice'
  10. GENEX
    GENEX
    I work for a company developing DSD recorders for Sony, and have thus had experience with both SACD and DVD-A. I much prefer the sound of SACD, but accept that PCM recording may be here to stay. All I can say is listen to SACD before ignoring it as a format. I may be biased, but our machine can record at DVD-A resolution as well so we can't lose out in the format war. I like the idea of the all-encompassing new Pioneer machine, apart from the predicted £6000 price tag!
  11. bananas
    bananas
    Dec 29, 2000
    130
    West Byfleet, Surrey
    +13
    I would stay with the 919..
    Ive just upgraded my 717 to a Sony 9000es, and really you would be hard pushed to notice the difference in audio and video (thats ignoring the SACD and component aspect)
    I think you would get much more 'bang for the buck' if you put that money towards a bigger TV, or better subwoofer etc. Of course you may already have those..but you get the idea.
    Unless youre looking for DVD Audio, or SACD, I doubt very much you could justify ditching the 919...(anyway, what would you do with all your great LD's?!)
    Hope that helps!
  12. Ars longa, vita brevis
    buy another sub, head for the 8.4 system charlie whitehouse was talking about in another thread, that would be pretty coo'
    'which is nice'
