If I Daisy chain more than 1 VCR to the Aerial cable, will I lose signal quality?
Discussion in 'Digital TV & Video Players & Recorders' started by Duster, Aug 7, 2003.
Tags:
  1. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Will I lose signal quality if you daisy chain through more than 1 recording device with a aerial cable?
    Thanks,
  2. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Should be OK with VCRs, because they have an internal amp for RF pass through to avoid loss. I think you might see a small increase in graininess though, due to the multiple connections.
  3. Duster
    Duster
    Dec 4, 2002
    421
    UK
    HI,
    Thanks for reply,
    The aerial cable would first going into my DVD recorder, then into my S-VHS VCR, and then into my TV.
    Does this sound OK?
    They all connect to the TV with their own SCART cable.
    Thanks for reply
  4. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Yep, that's the way to do it, just make sure that the Scart from the DVD is carrying RGB and the Scart socket on the TV is set to receive RGB. Do the same for the S-VHS VCR, making sure this is set for S-Video output and the TV for S-Video input. Then connect the DVD and VCR together if you want to make DVD copies of any VHS recordings you need.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Also get good cables between the units as the mains leads motors etc are the most likely cause of interferance. You could get a 4 way masthead amp and give each its own clean signal>
    Pricey but makes the inevitable digital upgrade all the more easy (when manufacturers start putting digital decoders into items like DVD recorders etc Which should be in a couple of years...
    Ignore above statment (duster) just noticed you are not in the UK!!!!
    But left it in as others who are may find it useful
  6. Duster
    Duster
    Dec 4, 2002
    421
    UK
    I'm from the UK, but i'm over in Germany at the moment. I will be returning in the next few years.
    Thanks again guys, for good replys.:smashin:
