@Fergal82
Just had a quick question about the balancing again, I think I've done it now which is a massive relief but I wanted to ask about the rad we have in our passage that's connected to the thermostat. Do I balance that the same way as the others or does that need doing a different way? Also it seems like the rads that are closets to the boiler heat up first regardless of whether they're upstairs or downstairs, so I may have the rad located directly above the boiler on the first floor and then the one in the room adjacent to the boiler heating up first and then the two furthest which are the upstairs bedroom and downstairs sitting room heating up last does that make sense to you?
I was under the impression that the upstairs rads would heat up first then the downstairs ones in some logical order but it doesn't seem to be that way with my heating system, just wanted to see whether this was something you had come across?
Thanks again and Happy New Year
