If anyone wants advice on gas/central heating/boilers. feel free to ask
liamthefirst
I have been on this site for a while now and I have noticed I ask a lot of questions and get a lot of very good advice.
Well I'm pretty newish to av so can't help many on that (maybe one day) but one thing I do know about is anything gas/central heating related.
Been doing it since 16 and in 31 now. I work for a big British company (most people like to moan about) and my dad has also worked for same company since the same age. If I don't know something chances are he will. So feel free to ask me for advice.
Liam
danmc_82
Its amazing how many CH/Gas/Plumbing questions that come up in GC. Any chance of a sub forum Mods?
John
There are a few, but not that many
shahedz
Awesome. I am actually researching some boilers now. Was going to settle for Worcester Bosch or a Valliant.
What would you recommend? 1500 sq ft bungalow, 2 bathroom.
Also Intergas were recommend- what's your view on them?
Thanks!
Lee
On a couple of occasions I've had the boiler not switch off at the time the timer is set to.
On the timer it is showing that the boiler should be off but the boiler hasn't turned off. If I change the temperature on the timer to technically restart the boiler and then drop the temperature the boiler will then go off.
Hope that makes sense.
Any idea whether this will be a boiler or timer problem?
liamthefirst
Thanks!
Can't comment on intergas boilers as iv never come across one yet. But if it was me I would stay away from Lesser known boilers because of part availability.
I would recommend a Worcester green star
liamthefirst
Could be a few things what boiler/system have you got? Without knowing i would say my Moneys on you having a normal system and the problem being diverter valve or zone valve sticking.
Let me know Boiler system and will try to help you out.
Liam
Lee
It's a ideal logic+ boiler with a Solus room thermostat timer that we have in another room that operates the boiler.
liamthefirst
Ok so it's a combi. I guessed wrong. It could be a few things I'm afraid.
So it's a programable roomstat? That would be the first thing I would look at, but without looking its hard to say tbh.
Liam
We had Potterton installed 2 years now and I havent had a service on it yet. I know they need an annual service but not sure that is required when they are new. Would you recommend a service this year or can I put it off one more?
Lee
It is a programable roomstat. I'll get that looked at first. Thanks Liam
Epicurus
I've had this problem with my combi as a result of the diverter valve clogging up and not operating properly.
liamthefirst
Although I would say its not as important as it use to be with older boilers I would defiantly get a service check as you don't know how the boiler is burning. It probably fine. But always worth getting a proper check.
A service on a new boiler is very different to an old boiler, as they very rarely need stripping down and cleaning. so shouldn't cost the earth (depends who does it)
Liam
Andyh4324
Liam
Also the manufacturer will insist it being serviced every year to keep the warranty. Something to remember with some of the manufacturers offering 5 year warranties now.
leo79
Could have an off temperature which is set to high or optimum start which I know Honeywell have. If it has an optimum start the stat will decide when to turn on and off to maintain the set temp that you have it set at. You should be able to disable this in the installer settings.
If you have an off temperature might be worth turning it down. The Honeywell and Drayton ones I fit I always turn the off temp down to 5deg because when customers want the heating off they want it off, they don't expect it to be off but come on if it drops below 16deg.
Could also be external frost protection, this will overide everything if it kicks in. This could be next to your boiler if in a garage/outhouse/loft etc. Or integral to the boiler. Or both!
ldoodle
A couple;
I may have an imminent requirement to re-do all the rad pipework downstairs as it's all surface mount. I think it's a concrete floor so will need to chase out paths etc. It's a combi.
What are the 'air space' requirements around the pipes. I probably won't re-concrete them in, just 'cap' them off with a timber lid for future maintenance.
Will use Speedfit.
Also, on another post I did earlier, I asked about having different locations as zones, each with a separately programmed temperature (never got a definitive answer)
zone 1: towel rads, always on 24x7x365
zone 2: upstairs, warmer 24x7xwinter only
zone 3: downstairs, cooler than upstairs 24x7xwinter only
If I had such a system, would I want/need TRVs on each rad? How much would such a programmer cost?
Thanks!
Wahreo
There are some very quiet sections on AVF. I know for a fact that a Tradesman section would do incredibly well on this site but can see why Admin haven't done it or wouldn't consider it as that's not really what AVF is about.
Amazing how many Boiler Questions there are. Possibly seasonal?!
liamthefirst
ldoodle said:
A couple;
Will use Speedfit.
Not really a requirement just make sure it's properly clipped and not touching the timber as you will get knocking when pipes are heating up or cooling down.
Thanks!
Different zones like that are good if your starting from scratch. But adding to an existing system would be a pain.
And yes to trv's. Iv got two zones in my house but still like different temperatures In Different rooms.
There are loads of 3 Chanel programmers Not very expensive. The expense is if you were to use wireless programable rooms stats.
So many options tbh. Also alot of work. You need to see how your system is pipped in first.
Liam
davepuma
I had my combi boiler (Worcester - 19 years old/serviced annually) serviced recently but I have found that the water is boiling hot for a few seconds and then goes tepid. The engineers that come out tell me that I should really get a new one but as long as it works, I'm happy to carry on with it until it's knackered.
I'll have to get them back in again to have a look at it but is this the beginning of the end. It's been pretty much trouble free throughout its life AFAIK with only a couple of parts changed at service and a new control unit fitted.
liamthefirst
ldoodle said:
A couple;
Thanks!
Forgot to say the best bet with the towel rails would be to add electric timed element.
liamthefirst
What model Worcester is it? CDi?
Just because it's old doesn't mean you need a new one.
Could be the thermisteor, diaphragm in the diverter valve or flow switch.
Let me know what model and I will try to help you out.
Liam
Flimber
Worcester RSF 24i Junior.
Pressure gauge on turn-on goes bonkers ever few seconds for a few minutes and then settles down.
Is this a sign of a failed/failing/struggling heat exchanger or could it be something else ? System is sludged and being X800'd ASAP (X400 didn't do that much).
Ta.
liamthefirst
Ta.
Apart from the gauge "going bonkers" what is the problem.
Flimber
Kettling noise accompanying, clattering sounding like a nunchuck in a washing machine.
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
