iec plugs
Discussion in 'Home Cinema Building DIY' started by dexter, Mar 1, 2003.
  1. dexter
    dexter
    Jan 27, 2002
    196
    Any ideas where I can get a CLOVER IEC plug (like the one that goes into a Panasonic PTAE 100 projector) - I want to improve the mains cable but need the plug to finish the job!
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Maplins, RS etc should have the right one.
    I assume you mean the standard IEC plug?
    The sticky at the top of the DIY forum covers these sort of things.
  3. Flimber
    Flimber
    Sep 22, 2002
    13,362
    Yorkshire
    +4,477
    Cloverleaf is used on some laptops too. ARD carry such leads which you could strip and you could then put a more regular socket inline (leaving the bit in the projector as a trailing lead). I've never seen the plugs for sale in rewirable form but I've never looked properly. If anyone, CPC should be the people.
    HTH,
    Mike.
  4. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Just checked the CPC catalogue, and can't see them in there. I know ARD do them, though.
  5. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    dexter
    Maplins sell the lead 1.5m I ended up buying this and then extending this with another piece of flex. (soldered and heatshrink of course)
    couldnt find a plug on its own.
    Another option is to install high level outlet to plug striaght into. but i think this looks ugly, but it may work in your instalation.
    good luck
  6. dexter
    dexter
    Jan 27, 2002
    196
    Thanks for the advice guys - one thing though - who are ARD and are they on the web or do I have to phone them?
    Dexter
  7. Dinsey
    Dinsey
    Dec 14, 2002
    ARD product code 210-00287
    Think its what u after
  8. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    No, it's NOT a straightforward IEC connector - unless they've changed them.
    You need something like prod code 210-00658 - this has the cable attached though - they don't seem to do a rewireable version. I'll check with CPC and Rapid for when I order the DIY mains cable stuff, and if I can get them I'll order a couple, and let you know.
    Richard
  9. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    I thought I would drag this up from the depths, I also need a clover-leaf (C5) IEC plug so I can make up an extended cable. I have searched around and can't find one anywhere?
  10. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    No, still no luck!!! I got two mains leads with my projector, so chopped up one of them to extend it. Not ideal....
  11. John
    John
    Dec 13, 2002
    10,969
    +2,660
    Blimey , I thought the on I brought back looking for figure 8 iec connectors was an old one :D
    (still not found one other the the tiny one available in maplins :( )
  12. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    It is amazing that nobody can find one, they are so popular with laptops and projectors etc....
    Anyway, if anyone ever finds any please let us all know.
  13. alpha10
    alpha10
    Jan 22, 2002
    3,197
    Essex
    +192
    I thought I would include it here, as someone on the projector forum appears to have found them for us, strange though, I have looked at Maplins a couple of times :confused:
    [snip]
    hi
    order code hl44x from maplin 2.49+ p&p
    cpc may be cheaper will find price 4 you.
    jas
    [snip]
