ie6 & aol side by side
Discussion in 'Desktop & Laptop Computers Forum' started by hammy2891, Dec 15, 2004.
  1. hammy2891
    hammy2891
    not realy htpc related i know but it is pc related (or idiot related)
    How do i get i.e6 to work with my aol broadband connection,or how do i get wmp10 etc to retreive info from the net using aol ? am i asking the impossible ?
    total novice so go careful !
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    The only idiot related thing here is that you are using aol in the first place... lol
    Anyway, there shouldnt be any problems with either of those points mentioned, they should find the connection and go, if not then aol 10 is a very strange version. You could try a reinstall or check the settings in IE6 or WMP for how they connect to the internet.
