IE status bar switch! where the ....?
Discussion in 'Desktop & Laptop Computers Forum' started by Cool-hand, Nov 22, 2003.
  1. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Can you help? Everytime I open a new window in IE, i lose the status bar at the bottom. I have to goto VIEW, then select/check the STATUS BAR option. It is a real pain.
    I cant find the switch to keep this on all the time with old or new windows.
    Do you know where it is?
    CH
  2. InsertNameHere
    InsertNameHere
    Sep 17, 2003
    264
    London
    +3
    I had a similar problem a while back, but I did a search on Google Groups and came up with the following:
    If your status bar disappears when opening a new IE 6 browser window:
    1) With (only one) IE open, click View, select: Status Bar
    2) Right-click on IE's Toolbar and select: "Lock the Toolbar"
    3) Hold down the Ctrl key and click the close button (upper right)
    4) Open Windows Explorer, click View, select: Status Bar
    5) Right-click on Explorer's Toolbar and select: "Lock the Toolbar"
    6) Click Tools | Folder Options | View tab
    7) Click the "Apply to all folders" button.
    8) Hold down the Ctrl key and click the close button (upper right)
    9) Open IE to any page, right-click on a link and select: "Open in New
    Window"
    10)Verify that these Registry entries exist:
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
    "Show_StatusBar"="yes"
    "Show_URLinStatusBar"="yes"
    Credit goes to Mike Burgess.
    Hope this helps,
    Alex
  3. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Thanks Alex :smashin:
    Like CH this is something that has annoyed me for ages that I haven't been able to sort out :blush: I eventually decided that it just couldn't be done!
    Tried the "lock toolbars" trick and now it works exactly as I'd like - the registry entries aren't present which is a bit bizarre, but since it's working I can't complain :)
    Thankyou!
    K.
