IE settings and Java
Discussion in 'Desktop & Laptop Computers Forum' started by scrapbook, Dec 19, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    I am not sure if anyone can help me with this.
    There are short cuts on some websites I do not seem to be able to open/work on my home laptop, but work fine at work on the pc I have..I have a feeling that maybe it has something to do with java settings...?
    If i try and open the owners manual at this site I get nothing, but works fine at work
    http://www.yamaha-audio.co.uk/homecinema/amplifiers/dsp-ax750se/
    Can anyone suggest what i may need to tweak?
  2. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    You might have a popup blocker turned on at home, Google toolbar blocks the popup containing the manual on mine until I allow popups on this site.
    If a new window appears with this URL:
    http://www.yamaha-audio.co.uk/pdfs/manuals/DSPAX750SE.pdf
    then it might just be the speed of your connection, the file is 3.8Mb.
    If you right click on my link above and choose "Save Target As" you should get the file.
  3. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Thanks Bob, spot on!!
    Ad blocker on the Norton Firewall..turned off and works fine!!:smashin:
    I appreciate the assistance.:clap:
