IE and Dr Watson problems
Discussion in 'Microsoft Windows' started by baldybonce, Jun 15, 2009.
  1. baldybonce
    baldybonce
    May 6, 2003
    937
    28
    Brighton,England
    +38
    I was using the pc at the weekend and seem to have picked up 'Dr Watson Postmortem Debugger'. This now means that IE is unusable as pages do not load and stay on screen, just get IE error report. We have scanned pc twice using AVG and apart from tracking cookies which we cannot remove there is no threats present.
    Does anyone know how to remove this pile of c**p from my pc?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,732
    Norfolk
    +2,493
    Doctor Watson is part of Windows, not any sort of Malware. It's what windows launches when a program crashes. Ignore it, and try and find out what the problem is that IE's having. Does Windows XP have the shortcut to launch it without add-ons?
  3. baldybonce
    baldybonce
    May 6, 2003
    937
    28
    Brighton,England
    +38
    Sorry not very good with computers, how do I do what you are suggesting, any sequence I should go through?
  4. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,732
    Norfolk
    +2,493
    No, you basically have to try things to find out what the problem might be and what it isn't going to be. For Example, you could try downloading another browser or two (for example Opera, Chromium or Firefox) and if they crash or otherwise refuse to display the pages you know the problem isn't likely to be with Internet explorer.
    Launching IE without add-ons; the option is under accessories>system tools in the start menu in Vista, but I don't know if XP has the option.
  5. baldybonce
    baldybonce
    May 6, 2003
    937
    28
    Brighton,England
    +38
    Thanks to my bro in law we have loaded Opera and this works fine with all websites so must be IE
