idvx playble home cinema systems
Discussion in 'Blu-ray & DVD Players & Recorders' started by nowonda, Oct 8, 2004.
  1. nowonda
    nowonda
    hello there to everyone!
    i'm a total rookie in home cinema systems and i got a lot of questions.. but one to which i haven't found the answer yet is whether are there any home cinema system capable of playing cds in divx format?
    if not, can something be done in order to make a "non-playble divx" home cinema system play a divx format cd?
    thanks.
  2. TOM ALLEN
    TOM ALLEN
    Jun 26, 2002
    431
    Liverpool - The World in one City
    +17
    Hi there, have a look at Amazon.co.uk site, I bought a Medion 40814 £52 odd delivered, play allkinds .
    So, have a look; you won't be dissappointed
    Good Luck! :thumbsup:
  3. sapper44
    sapper44
    Feb 12, 2004
    551
    uk
    +64
    Firstly welcome to our forums.If you are looking for a all in one systen i.e dvd with all the speakers then you need to ask this question in the all in one section of this forum.There is a big thread going on about the Philips 3900SA all in one system there now.If you are looking for a divx player there are quite a few about so look around this section,or you could goto www.divx.com. Look in there forums in the hardwear section and you should find a few tips there.Happy hunting
