idtv
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jelly, Dec 19, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    i have an idtv which i cannot get a decent signal on from the roof aerial would i be correct in thinking that if i was to get an signal from an ntl box(where my telephone is ran from ) and use that as an aerial would it work????
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The DTT signals that your TV requires are not present on any cable feed, you would be able to tune in to a handful of analogue channels that are FTA on cable.
    Since you are getting some signal from the aerial a booster or an upgrade to a wideband aerial might solve your problem.
