Idiot Question
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, Jul 9, 2002.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    OK, I know this is a bit dumb.
    Got an AE100, with a 7ft electric screen (16x9)
    When I watch 2:35.1 movies it quite obviously doesn't quite fit the 16:9 ratio screen....leaving a bit of light spillage top and bottom.
    Is there a way of eliminating this with a HCPC???
    I suppose I could align my screen better, budge it up a little etc.
    But what about Powerstrip...can Iforce it to mask this area so you don't see the light top and bottom?
  2. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    Only satisfactory answer is to find a way of masking the screen. I use black velvet masking bars attached with velcro. (Home made, cost under £20)
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,649
    UK.
    +3,148
    Chris,
    The grey bits above and below are due to the light coming from the pj, so DMs answer is the only way to eliminate it.
    DM -
    I'm thinking of doing the same thing with my screen - it's 7ft wide and I was wondering how to make them so they don't bow.
    Did you make any means of supporting the fabric? Any pics? :)
    Gary.
  4. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Sorry, no pics. The black velvet does its job far too well!
    Yes, I did use supporting material, some plastic sheet usually used for sign making, about 3mm thick. To be honest, its too heavy, but it hasn't fallen off yet!
    The next one I do will use aluminium channel (for rigidity with a thinner and lighter backing board. The stuff they use for estate agents signs if I can get it.
    I left the bottom mask with fabric hanging down (edges sealed) and hinged the top one so I can switch from 16:9 to 2.35:1. Not as elegant as a Stewart but a hell of a lot cheaper.
  5. jonny m
    jonny m
    Mar 22, 2002
    405
    Apart from masking the screen how about putting the masking on the lens instead? Would this cause problems with light return etc.??
    Far less farbic required :D
    Anyone try this?
    j
  6. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Unfortunately, you can't mask at the lens, because the edges would be very blurred and indistinct. Thi image is only focussed on screen.
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Sorry but I've got no pics of my solution, but it involves using carbon fibre stiffeners for lightness... Much easier than you think, they're sail battens. I had them in the garage, I'm sure there must be others in that position, but windsurfing/dingy shops sell the stuff. Not that wildly priced these days, and if you get strip rather than rod, they're very stiff in the required direction.
  8. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    MAW,
    Thanks for the tip! I'll use those next time - perfect.
