Identical monitors - one quite yellow
irvsax
I just purchased three identical Dell monitors. The one I have set up centre has a yellow tint that isn’t good and I can’t adjust anything to change it.
has anyone had this?
Also, I gave two of my old monitors to my partner and purchased an identical third and that new one has a yellow tint.
It’s crazy! The whites are just yellow and its not ok. Should I return the yellow ones?
I have tried colour profiles and it doesn’t change much and adjusting rgb doesn’t really make the white better either.
jimscreechy
Yes, you should definitely return it. If resetting to factory default doesn't fix it, then the monitor is faulty. Don't even blink, just send it back.
unlikely but have you swopped the monitors around to see if what socket or even PC there connected too makes any difference ?
