Identical memory sticks reporting different capacities
Discussion in 'General Chat' started by Foebane72, Jan 5, 2012.
  1. Foebane72
    Foebane72
    Mar 19, 2006
    3,402
    Cardiff
    +279
    I have three 16Gb Readyboost-enabled USB memory sticks from Play.com, and I've just discovered that even though I've quickformatted them all from Win7 with the same settings and choosing default values, that at least one of the devices is reporting a smaller memory capacity.
    Why is that?
    Also, I know some memory is lost to the OS and the filing system on the stick so I'm not surprised I'm not getting the full capacity mentioned, but why would the capacities vary from (supposedly) identical sticks?
    Also, if I chose to format from FAT32 (which these are as default) to NTFS, would it cause more problems or even damage to the sticks? And would it only take effect if I checked off "Quick Format"?
  2. Marc
    Marc
    Jul 8, 2004
    11,723
    Titchfield
    +1,101
    is it a lot smaller, or just by a small amount? Can't remember if the Win 7 format tool sets a default cluster size or keeps whatever the drive already had, so it could be that they had different cluster sizes and Windows has just kept it the same when formatting.
    Formatting them to NTFS will probably take up a bit more space on the disc iirc but it won't cause any problems, except with devices that can't read ntfs like some Smart TVs, PS3 etc, and you can do it with Quick Format still ticked.
  3. Foebane72
    Foebane72
    Mar 19, 2006
    3,402
    Cardiff
    +279
    Well, two of them said 14.9Gb and the errant one said 14.1Gb, so it's not a major difference. I did click on "Device Defaults" when quickformatting all of them for FAT32 so they should all be the same.
    Is there a way to find out what the "cluster/allocation unit" size is in a USB stick without losing data? All Win7 tells me in Properties is that they're all FAT32 with different capacities, so is there a free utility available?
  4. Foebane72
    Foebane72
    Mar 19, 2006
    3,402
    Cardiff
    +279
    Also, I should point out the different capacities were mentioned when I went to format them, so would that be altered as well?
    And why, in the Format dialog, is the memory capacity mentioned in a drop-down list, like the cluster sizes and file systems, when it's can only be one number and usually is? Lazy programming by the MS people, I fear.
  5. Foebane72
    Foebane72
    Mar 19, 2006
    3,402
    Cardiff
    +279
    Well, it's confirmed.
    I formatted all three to the same settings (FAT32, 8192 cluster size) and it seems the original capacities are different for exactly the same type of device.
    So, is this common?
  6. Marc
    Marc
    Jul 8, 2004
    11,723
    Titchfield
    +1,101
    i would have thought they should all be the same. See if you can find something that tells you the Raw size of each disk. If they're all the same physically then perhaps one has some bad sectors which Windows is stopping the disk from using.
  7. Foebane72
    Foebane72
    Mar 19, 2006
    3,402
    Cardiff
    +279
    Thanks.
    Yeah, I thought of bad sectors, but I thought that was just an HDD or FDD thing?
  8. pandemic
    pandemic
    Dec 28, 2008
    4,578
    +1,167
    It just means they've used 2 different flash memory chips in the usb drive. Fairly rare when buying from the big suppliers i.e. sandisk, but not uncommon for the cheaper 'no frills' stuff.
  9. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    I've got 2 blue play 16GB USB sticks, one has a green LED the other has a red LED, the RED led version writes faster than the Green LED version.
    Can't compare capacities right now as 1 stick is at my parents.
  10. Foebane72
    Foebane72
    Mar 19, 2006
    3,402
    Cardiff
    +279
    Well, I just did a check on all three with CHKDSK /R, and none of them have any problems. So it must be down to the different chips used.
