Ideas.
Discussion in 'Home Cinema Building DIY' started by didjerama, Aug 18, 2003.
  1. didjerama
    didjerama
    hey all
    anyone got any pics or ideas for a home cinema/htpc setup for a room thats about 6ft X 7ft (my bedroom:D).
    Cheers.
    Didjerama.
  2. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    6x7 ??
    Good luck !
  3. didjerama
    didjerama
    yer. I was thinking about getting a 24" widescreen tv and then getting a 5.1 dts/dolby av amp and some speakers. but have all the audio sources going to the amp, i.e my xbox and pc. Also getting a good dvd player.
  4. khalilk
    khalilk
    HOwdy ,
    As you ar ealready short on space .. you may want to consider Plasma.... LG have brought a new plasma display which is is pretty good and cheap too .. here in Oz 109cm (42 inch) plasma LG is selling for 4000 ozi dollars ! not bad at all ! good price me thinks.
    anyways .. combine it with a 5.1 speaker set up and AV reciever DVD player , VCR , Cable anything you want house it all in agrooving table or custom make your furniture to accomodate your toys and away you go !
    depending on you budget and what you prefer .. you can also get flat panel speakers ..i never heard them so i dont know what they are like .. also you can speakers which can be mounted flush in the wall or roof (ceiling) ... good luck..
    would be good to know what you end up getting and post some pics of the cool HC room you make of it !
    HAVE NICE DAY :) ...KK
  5. WBC
    WBC
    Personally I wouldn't touch flat panel speakers. I have a set in my dining room which are fine for background music but THAT'S IT!!!!!
    They would definately give a very bad sound for 5.1.
    Stace :D
  6. NicolasB
    NicolasB
    Oct 3, 2002
    6,458
    Emily's Shop
    +898
    Buy a dual-SHARC Tag AV32R, get the Dolby Headphone upgrade, then buy a decent headphone amp and some Sennheiser HD600 'phones and don't bother with speakers at all.
  7. WBC
    WBC
    NicholasB
    Would it not work out cheaper to buy a big house!!! :D
    Stace :D
  8. NicolasB
    NicolasB
    Oct 3, 2002
    6,458
    Emily's Shop
    +898
    Not with shops offering anything up to 45% discounts on ex-demo Tag McLaren kit at the moment. You can get a passable 2nd hand headphone amp for <£100, and some new HD600s for about £120. (Or 580s for only £80, according to www.priceguideuk.com).
  9. WBC
    WBC
    Might have a look myself!!!!
    Stace :D
