Ideas for valve project /purchase using these:
Nic Rhodes
Right a slightly unusual approach here. I have some great valves I am not really using at the moment and would like to look at either purchasing something or building something to use then, to try them, learn about them more.
Do people have any ideas for any of the following valves? What I can use them for isn't really important at this stage.
6SL7GT
6SN7GT
6SJ7GT
6L6
EC8010
E810F
2A3
45
PX4
PX25
alexs2
PX4 and PX 25 should be nice for SETs....have you tried either the WAD forum or similar...they may also be helpful for ideas.
Nic Rhodes
No, I thought I would try here first for ideas re commercial kit thta might use them
Paul Williams
Here are a few of the kit sites I've come across
Triode Systems
http://www.triode-systems.com/modules/news/
Euro portal for DIT Hi-Fi Supply in Hong Kong
http://www.diyhifisupply.com/index.htm
Some of the same kits plus other bits are available from Acoustic Dimension's in the Netherlands
http://www.acoustic-dimension.com/
hope that'll give you a few ideas to start with?
Paul
