Ideas for sub cable?
Discussion in 'Subwoofers' started by gingerone, Aug 28, 2003.
  1. gingerone
    gingerone
    Dec 10, 2002
    2,386
    +286
    I'm looking to get a new subwoofer cable for my rel quake, any recomendations below the £40 mark?
  2. Tracey
    Tracey
    How long does it need to be, if you only need a short one there are wuite a few choices for that price, if you need somthing longer, I use the QED Qunex Two it's £44 for a 6m length, you can also get longer lengths and obviously the shorter lengths are much cheaper. Have a look at www.hificables.co.uk personally I don't think you need to spend loads on a sub cable as it's only a mono signal, as long as you have decent connectors which the QED has it should be fine. I'll probably get an REL sub soon and I'm sticking with my QED cable.
  3. gingerone
    gingerone
    Dec 10, 2002
    2,386
    +286
    I'm after a 3m cable, I'll have a look at the qed cable.
    cheers.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Also look at www.scorpioncables.com
    Got their sub cable and it improved the bass output from my Velo and I was happy with it before.
    Prices from £24 for 1m length.
    Mark.
  5. Smurfin
    Smurfin
    Aug 13, 2002
    20,522
    +3,837
    Alternatively use a cheaper cable and turn your sub up;)
    I've never really found much of a difference with sub cables tbh.
  6. wookie
    wookie
    Why not make your own?
    You can buy decent phono plugs and pro spec mic cable from maplins. (good shielding)
    If you can solder, it should take no more than 1HR to make....
    Phono cable with a seperate core (for grounding) is also available.
    This is not found on normal sub cables and alows you to conect sub to amp chasis to rid earth loop if amp is floating...
    Just my 2p's worth:smoke:
  7. Bassbin
    Bassbin
    Mar 16, 2003
    2,395
    48
    Leicester
    +56
    I bought a 10m Profigold cable from a good reseller on ebay who always has new 3,5 and 10m sub cables available. A 3m one can be found here .
    I'm using mine with a Rel Storm and now a new Servo 15 and I don't think it will be worth upgrading to anything more.
  8. gingerone
    gingerone
    Dec 10, 2002
    2,386
    +286
    I've ordered one of the new qed cables now but thanks for the suggestions.
