Dazza the Stag
I need your help and experience please.
I have a baffle wall that I need to create a door in to access the storage area behind and access the rear of the speakers etc.
The front of the baffle wall will be a layer of plasterboard and then a layer of mdf and then another layer of plasterboard.
The fixed acoustic screen will partly cover the door, which will be on the left hand side of the screen and the door needs to open with hinges on the left.
For looks it would be great if the whole wall including the door could be covered with the 3 layers as above. However I don’t believe there is then a way that the door could open inwards ?
Opening the door could also be a little tricky as the screen will cover where the handle would normally be, but I could get around that but putting a simply electronic lock on the inside and activate that remotely.
In summary I would really like the Door to be as hidden as possible, ie not something that is going to distract and to open inwards.
Any clever people with bright ideas ?
Darren
Darren
