Ideal sub position...
Discussion in 'Subwoofers' started by Adlopa, Jan 3, 2003.
  1. Adlopa
    Adlopa
    Nov 25, 2002
    74
    All things being equal, what's the considered opinion on the ideal position for a sub? As I've attempted to show below -- behind the front speakers (centre or corner) firing forwards or sideways; or in a corner in front of the front speakers, firing forwards or sideways? And on a similar note, while bass isn't directional, does it matter if an object (like a front speaker or TV + stand...) is immediately in front of a sub?
    Code:
                         ¦           <--SW   <--SW  ¦
                         ¦                 v           v   ¦
        -------------    FL         TV          FR  --------------
        ¦                                                       <-- SW     ¦
        ¦                                                               v      ¦
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    You are lucky to have several options on positioning, so the best way forward is to get a longer (5m?) sub lead and move the sub around until it sounds best. It is quite a lengthy process finding the best spot unfortunately. I suspect in a corner is NOT a good idea if you want good, clean, undistorted bass. Depends on the sub you have tho'.
  3. Roman
    Roman
    Feb 28, 2002
    331
    +21
    Be careful putting your sub too close to your TV unless it is magnetically sheilded as it will affect the TV picture geometry - as I am now finding out to my cost! (Assuming you have a CRT TV of course).
