Ideal height för wallmounted 42" plasma?
Discussion in 'Home Cinema Buying & Building' started by Funkybase, Jan 4, 2005.
  1. Funkybase
    Funkybase
    Jul 21, 2004
    69
    I'm planning for my new house. I want to wallmount my Viera 42". What is the ideal height?
    Does anyone have pictures on the backside of the Viera wallmounted (I'm looking for great clues in how to the nices wireings behind the wall...
    Thanks!
    /Funky
  2. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    I've read that sitting on your sofa the bottom of the plasma should be at eye level.......................mines about 1m from floor level.
    But people have them very high above fireplaces..................other have them so your eye level is centre of screen.
    you can also buy tilting brackets for the plasma.
    suppose its down to the individual + missus.
    maybe one of the installers on here will help
    cheers, tam
  3. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    I guess it all comes down to the size and shape of your room.
    Mine is about a metre off the floor, very happy with it's positioning.
    [​IMG]
  4. Funkybase
    Funkybase
    Jul 21, 2004
    69
    Thank you! :)
    I think that I will sit approx. 4 meters away from the plasma.
  5. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    The ideal height is the one that doesn't hurt your neck when you watch it. If you're sitting close to a screen high up on a wall you will probably suffer from neck ache. My retailer says that he had to put his plasma inside his fireplace (unused) as it would be too high above it. A plasma high up on the wall may look very pretty, but the important thing is comfort when you're watching it.
  6. kangaroojack
    kangaroojack
    I used a template made fom paper and stuck it to the wall at different heights, we ended going with the middle of the screen at eye level, if your lounge reclines you can go a bit higher.
  7. mooncat
    mooncat
    Dec 23, 2004
    29
    or a bit higher than that if you have to keep little prying fingers of the screen :D the kids love wipping jam across it :eek:
