IDE to SATA converters - any one used these ?
Discussion in 'Computer Components' started by jetinder, Sep 21, 2007.
  1. jetinder
    jetinder
    Sep 16, 2006
    1,594
    63
    +139
    I have 2 IDE hard drives which are brand new and are in good working order.
    On the internet i've seen IDE to SATA converters
    http://www.granitedigital.com/catalog/pg52_satabridgeboards.htm
    Do these give the same performance as IDE drive plugged in to an IDE cable or through converting from IDE to SATA does the performance drop ?
  2. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,774
    Outpost 31
    +215
  3. jetinder
    jetinder
    Sep 16, 2006
    1,594
    63
    +139
    Thanks for letting me know :)
    That means i can get a decent motherboard and still use my trusty old IDE drives and DVD burners with no worries :)
  4. BrokenArrow
    BrokenArrow
    Sep 7, 2006
    894
    28
    Berkshire
    +68
    There are also IDE PCI adapters like these but they're more expensive and take up a PCI slot which could be used for something else.
  5. jetinder
    jetinder
    Sep 16, 2006
    1,594
    63
    +139
    Naaaaaah i'll stick to the IDE to SATA converters which plug directly in to the hard drive as it saves me a PCI slot.
    Unlike full ATX motherboards of 2003 which had 5 PCI sockets + AGP slot, motherboards of today have 3 PCI slots, 2 tiny PCI slots + PCI-Express for the graphics card.
    So you have to work out which old PCI boards to use and which to bin.
    Pity you cant get converters which convery the smaller PCI slots in to normal PCI slots.
