IDE RAID - DigiTV issues??
Discussion in 'Desktop & Laptop Computers Forum' started by wyerd, Jun 21, 2005.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    Would the Nebula DigiTV card suffer from the same SATA problems if I used an IDE RAID controller?
    I have an Abit AN7 mobo with the SilicionImage 3112/4 controller. When I first built it nearly a year ago, I used an SATA drive which caused latency problems with the DigiTV card. I went back to an IDE drive, which failed last week. Luckily, I didn't loose any data, but to make any recovery from a disc failure next time a bit easier, I'm looking at redundancy.
    As I've already got a 160g drive and the replacement 160g drive on its way back from Seagate, I'd like to stick with IDE. I'm looking at RAID 0+1.
    Can anyone recommend a good controller?
    Thanks,
    Dave.
  2. mjn
    mjn
    May 24, 2001
    22,119
    Herts, England
    +9,874
    For RAID 0+1, you'll need 4 drives for starters.
    But it should be all ok, IDE is a different bunny to SATA.
  3. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Ahh okay....
  4. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Yup the hardware ones should be fine as there should be no need to push data across the PCI bus which is what I think is the problem with SATA on non-PCIe boards.
