I'd like to buy a 'basic' DVD recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chibouk, Sep 22, 2007.
  1. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    I currently have a Panasonic DMR-ES10, but the drive unit has gone and it won't read disks anymore. I only use it to record things from my Sky+ box, so don't need anything fancy.
    I want to replace it, but don't know what to go for. Any suggestions for a relatively cheap replacement? The only stipulation is that it uses DVD -Rs and not +Rs, as I have a lot of -Rs left over.
    Any help appreciated. :)
  2. HMHB
    HMHB
    Nov 11, 2001
    27,410
    Nottinghamshire
    +6,288
    I would definately go for one with a hard disk to make copying from the Sky+ box easier.
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,158
    +7,098
    I second John's suggestion.
    Also , there really isn't such a thing as a 'basic' DVD recorder. Once the basic technology has been provided, all the 'features' are relatively cheap to bolt-on, so they are always attached.
  4. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    Thanks for the advice so far.
    Why would a hard disk make thing easier? Would it allow me to view Sky TV while I was backing up a programme for example? At the moment I have to watch what I am recording, which isn't always convenient.
  5. HMHB
    HMHB
    Nov 11, 2001
    27,410
    Nottinghamshire
    +6,288
    Whenever you transfer stuff from Sky+ you have to watch what you are copying. I therefore usually wait until I have 6 or 8 hours worth of programs to copy and set them going overnight or at a time when I know I won't want to watch anything else on Sky. If you are recording to a 2 hour DVD then you can't do this.
    It's much easier to edit content on the hdd of the dvd recorder and then transfer it to DVD - you could then make 2 copies of the same recording very easily if you wish to make a secure backup copy.
  6. JimmyCobra
    JimmyCobra
    Jun 1, 2005
    233
    OLDHAM
    +8
  7. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    Thanks JohnG.... that makes perfect sense. I'm buying a second hand Pioneer off another forum to be going on with. I record stuff off TV for use in work (I'm a teacher), so I need something to use in the meantime.
    I'm going to save up a bit more cash and then buy one with a hard-drive.
    Thanks again for the good advice. :)
    (Thanks Jimmy too. :) )
