ICS on Incredible s
deribronco
Just upgraded from Gingerbread to ICS, one thing that is bad is the font sizes, they have gone smaller. Is there any way of changing this. I am literally squinting to read the writing
redboy1
Think if you go to settings while your on the internet and then go to Accessibility, you should be able to change the txt size.
Have you found your inc S quite laggy after the upgrade ? Mine seems to be especially while browsing.
g8tecrasher
Mine is awful Chrome is especially bad. There is supposedly a update on the way but I aint going to hold my breath
redboy1
Apparently a full factory reset makes it work a bit better. Unsure whether to do one or not though, having to back up everything.
I've sent an email to HTC about i, they are yet to reply.
redboy1
Htc got back and basicly said do a factory resest. Went ahead and reset it which has made the phone less laggy:) but still not as smooth as before ice, its mainly when browsing the web page when you scroll around the page can't load fast enough and I get blank parts on the screen.
Hopefully there will be an update to fix this.
