icestorm paint
Discussion in 'Projectors, Screens & Video Processors' started by BigGEORDIE, Aug 21, 2004.
  1. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    Hi can anyone tell me where to buy this icestorm paint . at the moment I am using crown matt emulsion with a non reflective finish. the picture look's good ,but I am reading that most people seem to be using icestorm 5 or 6 ,how good is this paint, or any other paint that anyone can recommend .Any help would be great
  2. Taz
    Taz
    You can buy it in any DIY store that has a Dulux colour mixing machine. (Homebase, B&Q, Focus etc)
    I went for a mix of 5 and 6 together.
  3. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Would also recommend 5/6 mix, 5 is too dark and 6 might be slightly too light depending on your viewing environment. Before i used Goo i had a 5/6 mix.
  4. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    thanks for the info , is the icestorm 6 darker than matt white, i only used the matt because it was non reflective ,but i do think that its to bright,and also I am new to all this. I own an x1, would I see an improvement using this goo stuff, and if so how much would it cost to paint the screen with that.
  5. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Icestorm 6 is darker than white, it is a very light grey.
    For me personally the goo is far better than the ice storm 5/6 mix, although the blacks are darker with the 5/6 so is every other colour. It is however more expensive and will cost about £80 to paint a screen as you should get away with half a litre.
  6. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    What is this Goo stuff ? Where can you get it ?
  7. Dr Pumpstain
    Dr Pumpstain
    ...and do you actually need a screen at all if you have a wall that can be painted whatever colour you require and can be used permanently to project images onto?
  8. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    No. If you were going to use mdf as your screen, a flat wall will do just as good a job. Just paint it with the right stuff, and from what I am reading, the right stuff is GOO. However I am going to give icestorm 6 a try as blacks and room lighting are not a problem.
  9. Dr Pumpstain
    Dr Pumpstain
    I have looked at Goo but which one is the right one as there seem to be a few different types?
  10. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    I used digital light grey top coat with a dark grey base coat.
  11. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    what pj are you using
  12. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    I have a Z2 which is LCD, i got light grey as i wanted it to last another pj upgrade which will be DLP. If i was keeping the Z2 or LCD then i would have gone with the dark grey top coat as well as the dark grey base coat.
  13. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    thanks for your help.
  14. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    No problem, when you have decided let us know what you go for and whether you are happy with it or not.
  15. Dr Pumpstain
    Dr Pumpstain
    I am looking at getting the TX100 so am I right in thinking that I need to go dark grey for both coats or am I putting two and two together...?
  16. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    If it is for the LCD only then personally i would go with the darker two coats of grey
  17. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    I went to B&Q and paid 2 pound for a tester of icestorm 6 . the tester done the job great. the picture is a lot better, blacks are even better and the colors are more real looking. thanks for the advice :thumbsup:
  18. Dr Pumpstain
    Dr Pumpstain
    what's the best way to apply the paint anyway? Brush or Roller or paint pad?
  19. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    I used a roller but reading one or two threads on here i think that a paint pad might give a better result.
