Ice storm Question - More info Required
Discussion in 'Projectors, Screens & Video Processors' started by Amelia, Jul 16, 2002.
  1. Amelia
    Amelia
    I am from Australia and unfortunately Dulux Australia don't have the Ice storm range and if they do, then it goes under a different name.
    The following is the only info I have on it so far:
    Ice storm 6 = 12632
    Ice storm 5 = 12630
    Ice Storm 4 = 12628
    Ice Storm 3 = 12626
    Ice Storm 2 = 12624
    Ice Storm 1 = 12621
    Can someone tell me a little more about what the paint is supposed to be for. For example is it a base coat or what? I assume there must be a brochure for it or something.
    Can someone scan it or provide a little more info on it.
    Thanks Again
    Amelia
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
  3. Amelia
    Amelia
    How do I find the Ice Storm range? What section would it be in the Dulux site?
    Amelia
  4. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I think you'll find it's a matt emulsion - not a base coat or anything else, so designed to go on walls etc. HTH - I'm amazed that the colour codes don't help!
  5. Amelia
    Amelia
    You're amazed . . how do you think I feel ? :(
    I couldn't believe Dulux Technical support couldn't help either :rolleyes:
    In any case I will try again later this week.
    Thanks Richard ;)
    Best Regards
    Amelia
  6. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Only other thing I can suggest is that someone mails you a painted swatch, and you get your Dulux bod to colour match - I'd offer, but don't have any of the aforementioned paint to create the swatch - give it a week or two and I may have...
  7. Amelia
    Amelia
    Hi Richard,
    Its been such a pain. I can understand local paint retailers possibly not know or being able to help, but dulux themselves?
    I have tried to find some downloadable info, but no luck so far.
    Best Regards
    Amelia
  8. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
  9. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I wouldn`t rtust the online colour thingy, when I looked at the colours they were different than on the colour card. (Depends on the monitor setup).
    If you are really stuck then I have a spare colour card I can mail to you, so email me if you need it.
    Chris
  10. Amelia
    Amelia
    OK, I just tried Icestorm 5 and the blacks were awesome, however I whites were effected. I also tried Icestorm 6 which is too light. I am going to go for something in between.
    I can't believe what a difference it made !!! :D
    Thanks to All
    Best Regards
    Amelia
  11. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Nice to hear the result! I'm just about to embark on my screen too....
  12. jrwood
    jrwood
    Are you using a filter?, you might find that a filter and ICESTORM 6 is the best combination. I think someone mentioned that they mixed ICESTORM 5 & 6 together to get the best result. I think if you can modifiy the gain for r/g/b on your projector you will get a much better picture too :)
  13. Amelia
    Amelia
    Thanks You Richard :D
    jrwood,
    Do you have any idea what filter I am supposed to use and can you pick one up at a Photography Shop?
    Best Regards
    Amelia
  14. jrwood
    jrwood
    Some people use CC30R or CC40R and some use the HOYA HMC FL-D filter like me. I personally think it makes blacks far better and if you adjust the bias/gain in the service menu in-conjunction with ICESTORM6 you get whites and very deep blacks. Like I said before Ive borrowed DLP's from work and their black level is far far worse than my LCD projector :) and I dont suffer bad whites (which I used to when I had ICESTORM 5) paint.
