ICE Related Question????
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by WBC, Apr 1, 2003.
  1. WBC
    WBC
    Guys,
    If you like cleaning then you could consider this an In Car Entertainment question.............If not sorry but I didn't know where else to ask!!!! :devil:
    Just picked up a car this weekend and the dash is quite grubby (used to be owned by a mechanic). What would you guys recommend to clean the dash and plastic with??????
    I'm not talking about the likes of Cockpit Shine (That will do the job when its clean) but something that can remove the base grime.
    Stace :D
  2. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    white spirit would be a good start, dont use too much or spill it or it will stink the car out.
    Then i've always found that the best stuff for the dash is regular furniture polish or windolene
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Cellulose thinners.
