Ican HD+ with OnDigital box
Discussion in 'Projectors, Screens & Video Processors' started by petrolhead, Jan 15, 2005.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    As a test I have also just tries my Pace Twin and agin nothing. I have the instructions for the pace Twin and the TV Scart outputs Composite and RGB so still scratching head
  3. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    Mine works fine - you do have to output RGB though (and this needs to be set in the pace menus...)
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    So have you got a pace twin or the OnDigi box thro the HD or HD+
    What scart to RGB+Sync lead do you use
    I have both boxes set to RGB
    Did you have to change anything in the Iscan
  5. Chris5
    Chris5
    Mar 21, 2004
    1,167
    63
    Herts., uk
    +122
    petrolhead, you didnt buy a RGB with TTL sync did you as I dont think that will work, you need Composite sync (RGBS). I've ordered a QED SQART LEAD type av19 (see http://www.qed.co.uk/cables/sqart/av19.html) to go with my HD+ when it turns up
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
  7. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    It's a Mark Grant special - didn't have to change anything, it just worked. Sounds like a case of wrong lead or wrong wiring/labelling. The sync has to be connected to get any picture, so try each phono in the sync input with random ones in the RGB inputs. If you get a picture then you've found the sync, then it's just a case of getting the others in the right order. I take it the Iscan is set up correctly (ie showing all the test patterns ok) and that you have plugged into the TV output of the pace (the other scart, TV2, doesn't do RGB).
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Not played with the test patterns yet.
    When I was messing about I noticed that when the the lead was plugged in I was getting a composite signal. Is the 4 phone, sync, not just the composite?
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    the old DTV/TV button o ondigital boxthing again? (knocks RGB OUT) I assume you have set box to RGB and are usin TV scart NOT VCR scart......
  11. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    quote: the old DTV/TV button o ondigital boxthing again? (knocks RGB OUT)
    Whats that and is is the same with the pace twin?
    I am using the TV Scart on both boxes and nowt, nada, not a bean :)
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    there is a button on sky/ on-digital boxes (labelled DTV/TV) thats that knocks the RGB signal down to composite causes hell with JS RGB>VGA boxes as the set-up menu shows RGB..... so works with DVD but not FV boxes.... both are RGB scarts????
  13. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Ok
    What a thicko I am
    The answer was in my posts.
    I had plugged the sync lead into the Composite socket and not the actual sync socket, ony notices the sync socket tonight after talking to the guy at Letropack who suggested i try one more time before returning the lead. Doooooooooooooooooooh
    All working now and what a difference. From comp in to comp thro the iscan was good but now using the rgb Wow, just sooooooo much better and that alone worth the price :)
  14. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Good news :thumbsup:
    Yeah RGBs is actually very good with a good RGB source...
    JJ
  15. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
    It is, but wouldn't it be great if someone could offer an SDI modified twin tuner PVR...
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Are u saying there is further room for improvement
  17. Pottsy
    Pottsy
    Apr 15, 2003
    288
    Leicester
    +6
