ical stuck on jul17th
Discussion in 'Apple Forum' started by mh8701, Sep 16, 2007.
  1. mh8701
    mh8701
    Dec 10, 2005
    239
    16
    i was wondering why it was like this on my ical for a while, but while browsing the thread "get your mac out for the lads" i noticed a few peoples screen grabs had july17th on theres to
    when i open up ical it goes to the right date, but iresets on july17th every time i knock it off
    just wondering why?? and what can i do to correct it?
    thanks
  2. rob_finch
    rob_finch
    May 8, 2005
    791
    43
    +94
    It's a static icon in the dock. No idea why 17th July was chosen, but it is always used.
    I did see a thread on a forum somewhere that said it could be updated using an application, but iCal had to open first so I didn't see the point of it.
  3. mh8701
    mh8701
    Dec 10, 2005
    239
    16
    thanks, strange one that! :confused:
  4. will1970
    will1970
    Dec 2, 2006
    +10
    I believe July 17th was the day ical was either announced or released not totally sure which one but think it was the former
    Will
  5. agoodey
    agoodey
    Dec 28, 2005
    196
    Oxford
    +21
    This will explain it all...
  6. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,525
    N.E. Lincs
    +103
    There's a nifty little program that will let you change the ical icon to the current date (when ical's not open). It's called iconical and is found here.
    Of course, you'll need to run it every day, and I suppose it all depends on how much you like July 17.
  7. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    That was the date it was originally released. Its not a fault.
    If you look around there are apps that will display a live date there even if iCal is closed.
